Transferring to PM from another provider while in the US.
plummer66
Hi.  Is it possible to switch over from Rogers to PM while I am in the US?
2 REPLIES 2
plummer66
thanks.  Was able to no problems.
slusagm
you can do that, only if you choose eSIM and choose a Canada/US/Mexico plan.  Some people tried
but you need your Rogers sim working in US to approve the porting, Rogers will send a text to your Rogers sim and a Yes reply is needed with 90 mins
