Transferring number from Fongo app
11-25-2018 09:03 AM - edited 01-05-2022 02:35 AM
11-25-2018 11:59 PM
I tried restarting the phone again today and it started working! Thanks everyone!
11-25-2018 10:04 PM - edited 11-25-2018 10:05 PM
@snoopy198726 wrote:Thanks for the quick answer. I will try waiting another day then.
Simply waiting is not going to make your service work.
The fact that you are not connecting to the Public Mobile network and don't have signal means that either yoru service was never activated properly, the wrong network or incorrect network type is selected in your phone's settings, or that your phone is incompatible.
Being able to connect to the network is independent of the number porting request. Ougoing calls, messages, and data should have started working immediately.
11-25-2018 01:11 PM
11-25-2018 01:10 PM
Thanks for the answer. When I login, it does show account status as active
11-25-2018 10:15 AM
i know someone who successfully ported fongo. As the other poster mentioned the new PM account activated immediately (meaning you can make outgoing calls) but the fongo number took a few days to port over properly (meaning incoming calls to the fongo number started to ring on PM sim and not just go to fongo voicemail).
11-25-2018 09:49 AM
@snoopy198726, account setup is immediate. However, porting from VoIP sources can take longer. If you are unable to connect to the network, I suspect there could be more than just port in progress. Is the self serve account showing an active service?
11-25-2018 09:07 AM
Porting from a voip number usually takes longer..24 -48 hours in most cases..
