To activate a SIM card
amydu
Hi
I was trying to activate a new SIM card. when i clicked on ACTIVATE SIM CARD, the screen went blank.
7 REPLIES 7
hey
you need to used different internet browsers .
or you can by Public Mobile Online Activation
https://activate.publicmobile.ca
or  you can buy it online from website public mobile
https://store.publicmobile.ca/collections/all
good luck Smiley Embarassed
amydu
thank you so much. it worked now. i used a different browser.
Amy
amydu
it worked. I changed to a different browser.
thank you so much for your help!
Amy
Raven_Jet
If things still don't work, try to clear all the cache from the browser. Then try again. It should work. Also, make sure your browsers are updated to the latest version.
@amyduwrote:
Hi,
i haven't put my SIM number in yet. i was at the very first step. the screen went blank. any idea?
thanks,
Amy
Try using incognito/private browsing mode or use another browser like Firefox or Chrome.
amydu
Hi,
thanks,
Amy
NDesai
@amydu First check if you were charged for activation. If yes, the activation might have gone through properly or partially. Insert the sim in your phone and see if it works. If you weren't changed, sim card should still be valid so try activating again. This time try using incognito/private browsing mode.
