01-25-2020 04:35 PM - edited 01-05-2022 10:25 AM
Checking my Usage History, all recorded dates for calls, texts, etc are one hour behind the actual times of my usage events. PM is recording my events in Eastern instead of Atlantic time.
No big deal, but wondering I can edit this myself or if it's fixable by PM?
Thanks,
bob
Summerside, PEI
01-25-2020 05:08 PM
@bashley wrote:Checking my Usage History, all recorded dates for calls, texts, etc are one hour behind the actual times of my usage events. PM is recording my events in Eastern instead of Atlantic time..
Once again I will mention VoIP.ms that I have for a home phone. VoIP.ms is all self controlled and help is by email or chat only. Sounds similar 😀. Not only can you generate your own invoice for specific dates you can also set the time zone in your profile so all records show for your time zone. I guess PM could do similar but perhaps is an enhancement cost that cannot be justified.
Interesting, @iPhoneUser . I just visited the VoIP.ms site. Sounds like you're overall satisfied with their service, including this enhanced ability to customize your records. Did you opt for this for $$ savings, convenience, or this customizable advantage? Do you have both a PM account and a VoIP.ms account? How long have you been using VoIP.ms?
Thanks!
01-25-2020 04:51 PM
Thanks,
bob
Summerside, PEI
I am not sure that you can change this...
01-25-2020 04:51 PM
01-25-2020 04:41 PM
Thanks,
bob
Summerside, PEI
01-25-2020 04:38 PM - edited 01-25-2020 04:40 PM
Everything in your self serve account runs on Eastern time....the community forums time zone can be adjusted.
