05-21-2018 10:25 AM - edited 01-05-2022 04:48 AM
I'm having trouble sendings texts. I have no trouble receiving them.
I have full bars, and have tried restarting my phone and removing my sim and reinserting it.
I have OnePlus 5T and am running Oreo 8.1.
05-22-2018 02:40 PM
@LEGO wrote:@srlawren I was not attacking or blaming you in anyway, it was just my opinion. Does Google’s messaging app needs data in order to send SMS? If it does, then it would be “patching” not “fixing”, as it would require additional resources to function properly. If it does not require data to send SMS, then it is “fixing” not “patching”. I hope I made myself clear! Peace!
@LEGO I think @wetcoaster has already addressed this question but I thought I'd confirm--Google Messages is a proper SMS/MMS client. Like any other such app, it does use data to send and receive MMS, but it is sent and received in such a way that PM does not count it as part of your data usage, but rather as part of your unlimited (or limited to 50 in the case of the $10 plan) texting plan component. RCS if and when PM ever actually supports it I believe will work similarly and not deduct from any plan data, but I could be wrong. So far, it's a moot point unfortunately. We'd have to ask some Rogers/Fido friends if RCS messages count in their data usage or whether they are covered by thier texting plan, since they are the only Canadian providers to offer RCS so far.
05-22-2018 01:33 AM - edited 05-22-2018 01:50 AM
@LEGO wrote:
@srlawren wrote:
@LEGO wrote:Well, it is not actually fixing the problem if you install different messaging app beside stock one. I would call it patching “working illusion”, that does not illuminate the actual problem, but just work around it.
@LEGO to be fair, the app I suggested he install is Google's stock messaging app, and they're building out for the future with RCS support etc. You could argue that it's the *real* stock app for all Android phones, but that most OEMs also provide their own messaging app which supercedes it as the default. OnePlus's OxygenOS is one of the lighter variants of Android but does still replace this app. However, there's nothing stopping you from grabbing Google's from the play store and using it instead.
Well, changing to a different SMS app has solved my messaging hick-ups - not sure why you are devalueing that approach as "it's not a solution to switch apps"... Not everybody has a background in coding and the time at hand to figure out where exactly the problem is - IMHO switching apps CAN be a solution and is worth a try.
From: https://play.google.com/store/apps/details?id=com.google.android.apps.messaging&hl=en_CA
Meet Android Messages, Android's official app for texting (SMS, MMS) and chat (RCS). Message anyone from anywhere with the reliability of texting and the richness of chat. Stay in touch with friends and family, send group texts, and share your favorite pictures, videos, and audio messages.
Google's "Messages" is a messaging app, sending SMS and MMS over your talk / text connection (remember to keep your data connection enabled to ensure MMS functionality, MMS will not count against your data bucket at Public Mobile).
If you are on the $10 50minutes/50 texts plan, messages sent by the app will count against the 50 texts (remember that 1 text = 160 characters)
Google's "Messages" is NOT a messenger app like WhatsApp, Facebook Messenger etc which are using your data (part of your plan or an add-on) for your conversations.
05-22-2018 01:04 AM
@srlawren I was not attacking or blaming you in anyway, it was just my opinion. Does Google’s messaging app needs data in order to send SMS? If it does, then it would be “patching” not “fixing”, as it would require additional resources to function properly. If it does not require data to send SMS, then it is “fixing” not “patching”. I hope I made myself clear! Peace! ![]()
05-22-2018 12:25 AM
05-21-2018 09:44 PM
@Reddogbluedog, you didn’t indicate which suggestion you used. Which one has at least fixed the issue for you so far?
05-21-2018 09:24 PM - edited 05-21-2018 09:27 PM
Well, it is not actually fixing the problem if you install different messaging app beside stock one. I would call it patching “working illusion”, that does not illuminate the actual problem, but just work around it. ![]()
05-21-2018 09:08 PM
This seems to have fixed the problem.
I'm going to test it over the next few days.
Thanks a lot.
05-21-2018 08:50 PM
@Reddogbluedog I have a 5T on 8.1 as well (Oxygen OS 5.1.1) and it's workting without issue. Are you using the OnePlus messages app? Have you tried Google's Android Messages? I'd recommend you try it if you haven't: https://play.google.com/store/apps/details?id=com.google.android.apps.messaging
If that doens't resolve it, you may need to contact the moderator team and ask them to re-push the messaging centre number to your phone. They'll know what this means. If you do need to reach out to them, here's all the info you need for doing so:
05-21-2018 08:04 PM
@will13am wrote:
@LEGO wrote:@Reddogbluedog Check to see if VoLTE is on. Go to SIM & Network settings and if VoLTE is on, turn it off. See if that works for you!
Also, you may try to turn off both VoLTE and VoWiFi.
What does VoLTE and VoWi-Fi have to do with sms? By the way Public Mobile offers neither feature.
Some people, experiencing same issue with OnePlus phones, were able to resolve this problem by turning off both VoLTE and VoWiFi. (Unfortunately, I cannot provide link, because system deletes my post!)
Even Public Mobile does not offers neither feature, having them on might interfere with sending SMS. You never know!
05-21-2018 07:18 PM
Some people experiencing same issue with OnePlus phones were able to resolve this problem by turning off both VoLTE and VoWiFi. Please, read this: click here
05-21-2018 07:14 PM - edited 05-21-2018 07:15 PM
Some people experiencing same issue with OnePlus phones were able to resolve this problem by turning off both VoLTE and VoWiFi. > click here
Even Public Mobile does not offers neither feature, leaving them on might interfere with sending SMS. You never know! ![]()
05-21-2018 04:38 PM
05-21-2018 04:29 PM
Try looking through the messaging app settings. It is possible that a setting may be interfering with outgoing sms.
05-21-2018 10:51 AM
@Reddogbluedog to confirm you are sending regular (short) sms not mms?
are you able to change sms program? have they worked before and now just stopped?
I know occassionaly i had issues with mms and waiting 24 hours seemed to fix the issue.
if you are a new customer then you migt need to set up your apn (especilly if you are sending mms) and data needs to be on,
05-21-2018 10:33 AM - edited 05-21-2018 10:50 AM
