Tag
denis2
Hi all,
can someone explain what is  (Add tags)
and how do i attach the question to my reply when i answer someone ?
Thank you, I could not find this on PM's site
7 REPLIES 7
srlawren
@denis2 wrote:
Actually they are both right, I had 2 questions in there.
@denis2 yikes, apparently I need to read better!  I need more coffee!  Sorry @Lieux, my apologies to you.
denis2
@srlawren
@srlawren wrote:
@Lieux wrote:
Ok you can to this with a @ first and you will see name appearing you can choose which do you want use...
And to attcach just click on the QUOTE right up when you are replying someone..
@Lieux while this is all technically correct, what you're describing is tagging a user, as opposed to adding tags.  Please see @Anonymous's explanation below for more info on what @denis2 was actually asking about.  🙂
Ok thanks @srlawren to let me know...those TAGS right of the box...Smiley Happy
srlawren
EDIT: corrected myself with strikethough!
denis2
@Lieux
@Lieux wrote:
@denis2 wrote:
Hi all,
Cool Got it,
Thanks
@denis2 wrote:
Hi all,
Tags are for search word optimization. When searching it can use the tags as part of getting results.
You click on the orange Reply button on a post that you want to specifically reply to and then click on the black Quote button just above this text entry box to pull in their text.
Lieux
@denis2 wrote:
Hi all,
