05-19-2017 09:54 AM - edited 01-04-2022 01:48 PM
I recently changed my phone and had to change SIM cards in the process. After that I broke my new phone, so I am looking to switch back to my old phone.
When I tried to change back the SIM cards using the self serve website, I received the following error.
"Sorry, the SIM card number is invalid or already in use. Please try again or order a new SIM card at publicmobile.ca."
Can anyone help me?
05-19-2017 05:59 PM
@imm1304 we're both right. He would have to catch the tube and then trasnsfer mid-Atlantic.
05-19-2017 05:55 PM
05-19-2017 05:35 PM
@Luddite guilty as charged 😉
Next time maybe try the subway back from London. I've heard it's much quicker.
05-19-2017 02:01 PM - edited 05-19-2017 03:17 PM
@Samianauman wrote:
@Luddite
How's was your great Britain trip and welcome back
Excellent thanks, though the bus back was quite slow. ![]()
05-19-2017 01:36 PM
05-19-2017 01:28 PM
@srlawren wrote:@teenteen I see my response is marked as solution. Did you manage to get back up and running using the adapter(s)? 🙂
@srlawren Oh ye of little faith! Solved is solved; or do you think an Oracle decided you had the best solution. OR did you mark it as the Solution???? ![]()
05-19-2017 11:54 AM
05-19-2017 11:36 AM
@teenteen the most recent SIM you purchased for your new phone, since it was ordered within the last year, should have arrived as a "triple-punch" card. Meaning it's a nano SIM card inside a nano-to-micro SIM adapter, inside a nano-to-full-size SIM adapter. Hopefully you didn't throw away the adapters after picking the correct size for your new phone? You can just use one or both of those (depending on SIM slot size on old phone) to get back up and running.
05-19-2017 10:46 AM
@CaNuCk07 If i look on my local used.ca site i saw an adappter for$3. teh link was just an example so the person understood what i was refering to.
another option, a shot in the dark and something i myself would try, is to stop at any cell store and see if they have any old/discrded multi-sims laying around that you could use an adapter.
05-19-2017 10:37 AM
@imm1304 true, i didnt take into account the long weekend. i was just thining about the $.
05-19-2017 10:33 AM
05-19-2017 10:21 AM
05-19-2017 10:20 AM
for $5 might as well order a new sim and have it in a couple days.
05-19-2017 10:17 AM
I'm assuming you are trying to go from smaller to bigger. you can always try to buy a sim adapter
im sure you can find something cheaper
05-19-2017 10:10 AM
Hi @teenteen!
Your old sim card is useless. Once you transferred your account in selfserve to the new sim card, the previously used card was permanently deactivated. You will not be able to simply register it again via selfserve.
You can either order a new sim card, or you can use sim card adapter so the new sim card can fit again in the old phone. These adapters are really cheap. Check the cheap local mobile shops/stalls in shopping areas near you.
05-19-2017 10:08 AM - edited 05-19-2017 10:10 AM
05-19-2017 10:07 AM - edited 05-19-2017 10:10 AM
When you switched to the new sim card, it deactivated your old one.
You would have to order a new one.
05-19-2017 10:05 AM
Please let me clarify. I have been an existing Public Mobile customer for about a year. I bought a new phone but my old SIM didn't work in the new phone (they were different sizes). I used the Self Serve site to switch SIM cards. I have been using my new phone for about a month now, but I recently broke the phone and I want to go back to my previous phone.
I tried to change the active SIM back to my previous one.
05-19-2017 09:56 AM - edited 05-19-2017 09:59 AM
