Switched phone
08-18-2021 12:57 PM - edited 01-06-2022 03:11 AM
Hi.
I just switched the Sim card to my kids new phone. She can text me, I can't text her. I can call her. How can I make the texting work foe me?
Phones
08-18-2021 10:06 PM
@Foxy1 wrote:I reset the network on her phone. I still can't text her.
She can text me. I have a Moto e5 play.
Hi @Foxy1
From her old phone:
- On your iPhone, go to Settings > Messages > Send & Receive. Select your Apple ID at the bottom of the screen and tap Sign Out. ...
- If the phone number that you want to remove belongs to an iPhone that you can't access, change your Apple ID password.
on her new phone...
Set up the phone number On the iPhone:
- Go to Settings > Messages and make sure that iMessage is on. You might need to wait a moment for it to activate.
- Tap Send & Receive. If you see “Use your Apple ID for iMessage,” tap it and sign in with the same Apple ID that you use on your Mac, iPad, and iPod touch.
- In the "You can receive iMessages" section, make sure that your phone number and Apple ID are selected.
- Go to Settings > FaceTime and make sure that your phone number and Apple ID are selected in the "You can be reached by FaceTime at" section.
08-18-2021 01:53 PM
08-18-2021 01:37 PM
08-18-2021 01:24 PM
Go to Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords,
or visit HERE
click HERE
- Open the Settings app on your Android.
- Scroll to and tap either "General management" or "System," depending on what device you have.
- Tap either "Reset" or "Reset options."
- Tap the words "Reset network settings."
or visit HERE
and go Changing APN Settings On Android device
click HERE
Ensure you have the correct APN settings by visiting HERE.
for iphone go to Settings > Messages > To turn iMessage on or off,
Turn your data on to send a Picture Messaging in world-wide,
if your data is off and your home internet wifi is on is not going through the Picture or a video Messaging,
you have to do this to is go through you will need to turn your data on to send a Picture or a video Messaging in world-wide,
make sure your DATA is on.
and do again Rebooting your phone means to turn off your phone and turn it back on again.
Good Luck
08-18-2021 01:12 PM
I have a Motorola, the other is an IPhone.
08-18-2021 01:03 PM
@Foxy1 wrote:Hi.
Perform a reset of the network settings on the phone.
Is this an iphone?
To check if your phone number has been set to send and receive messages, go to Settings > Messages and tap Send & Receive.
08-18-2021 01:03 PM - edited 08-18-2021 01:03 PM
@Foxy1 : iPhone? Other? Yours and the new one.
