Supported frequencys
01-01-2020 09:41 AM - edited 01-05-2022 08:49 AM
I'm looking at purchasing a Motorola G7 power (international) from Amazon.ca.
My question is about the frequencys that are used. The international version of this phone only supports 1/3 4G bands.. how would this potentially effect service?
My current galaxy s6 only supports 1/3 4G bands as well but it's a different band. Service on this phone is great.
1/3, 3/3 would you even notice a difference? Or bottom line the phone will just work..
Regards.
Phones
01-01-2020 02:06 PM
@dj_simms wrote:Thank you for the information. I appreciate it.
@dj_simms I just realised that you were asking about the power G7. If it's this one
Then it will also work well with Public Mobile because according to the specs it supports the same bands.
3G UMTS 850/900/1700/1900/2100 - 4G LTE Cat7 (Bands 1, 2, 3, 4, 5, 7, 12, 17, 28, 66) VoLTE - Dual SIM (Nano-SIM, dual stand-by)
01-01-2020 01:08 PM
01-01-2020 12:10 PM
@dj_simms , if you are looking to using a phone that has some of the supported LTE bands, make sure band 4 is covered. It's one of the most popular bands and will ensure very good coverage even if that is the only compatible band on the phone.
01-01-2020 11:54 AM - edited 01-01-2020 12:20 PM
@dj_simms wrote:I'm looking at purchasing a Motorola G7 power (international) from Amazon.ca.
Regards.
@dj_simms If you buy the Model XT1962-4 it will work well with Public's network. It supports the following bands:
HSDPA 850 / 900 / 1700(AWS) / 1900 / 2100
4G LTE band 1(2100), 2(1900), 3(1800), 4(1700/2100), 5(850), 7(2600), 8(900), 12(700), 13(700), 17(700), 20(800), 25(1900), 26(850), 66(1700/2100), 38(2600), 40(2300), 41(2500) - Dual SIM (Nano-SIM, dual stand-by)
01-01-2020 09:56 AM
