04-03-2016 11:14 AM - edited 01-04-2022 02:36 PM
Hi! Why not to be able to have a plan with data by an increment of 1 GB? From an accounting point of view, this would not change anything. In the plan selector on the web, it would be to change the data window with a drop down menu to select how much data I want/need. Unless it is a marketing practice to kind of force customers to choose chunk of data (that they will not use entirely). 🙂
04-03-2016 12:31 PM
You're welcome.
Cheers
04-03-2016 12:27 PM
Oh, I did not know... Thanks.
04-03-2016 12:24 PM
Hi @BAL!
You should post this under the "Public Lab" section as a New Idea if you want PM to formally consider this suggestion.
http://productioncommunity.publicmobile.ca/t5/forums/postpage/board-id/Public_Lab
04-03-2016 11:26 AM
That is true for other businesses but in some ways, it is against the PM philosophy of offering just what the customer need/want, is it not?
04-03-2016 11:21 AM
Getting people to pay for things they don't use is a common way to do business. Just look at gym memberships...
