Subscription
Thor2000
I can't subscription to a lower plan it only gives me the option for higher, i already pay $50 for 150GB (more then I need) an id like to change to something more practical
1 REPLY 1
Sansan
@Thor2000  unfortunately,  Public Mobile has made it more difficult to downgrade plans.
While downgrade is possible,  it it very unlikely that you will see something you like. You can only choose from what's available in your account.
