Sometimes I get 3G
xCameron94x
Hey Everyone! Merry Christmas and happy holidays. I just notcied something recently. When i was downtown Toronto (Dundas Square/Eaton centre) I had 3G data most of the time. Ive also noticed the same whenever Im in Kitchener. Also noticing I have less bars from time to time (average of 2 or 3 now). I'm using an iPhone 6. Could it just be a coincidence that I'm expiericing this. It just started happening recently
12 REPLIES 12
Vickel
@ManaI notice that when I unlock the screen it's on 3G then it switches to LTE.
On Rogers I rarely see the 3G icon come up.
yyzguy
I can usually predict (based on where I'm standing) when it will shift to 3G. As soon as I move a bit, it's back to LTE. My work phone is with Rogers - similar experience again based on where I'm located.
Mana
@Vickel @yyzguy how frequently are you guys switched to 3G and for how long does it stay on 3G?
Vickel
I have noticed since I switched from Rogers, that I also get 3G more than LTE.
Usually it keeps switching from LTE to 3G and back.
yyzguy
My office is near Dundas Square and occasionally I will also get 3G signal. I usually notice this when walking through my building - I will see the signal strength on LTE drop to 1 bar, then reappear as 4/5 bars 3G. I think this has to do with radio spots and coverage - some areas might be better covered with a 3G signal than LTE.
Remember that LTE runs on a different frequency than 3G.. and as such, it's possible you get stronger coverage depending on your environment (concrete building, interference etc) on one frequency versus another.
@Ionutis correct. Using standard conventions, Mb/s is in fact megabits per second. MB/s would be 8 times more. Most people in technology related industries would consider the use of "b" for byte to be a mistake.  This standardization is what's used to avoid confusion (although it's easy for people to still get these mixed up with each other).
Ionut
Please look again to my comment. There's no sense to fight. This things are set. Mb/s it's the regular representation form
I have seen MB referring to Mbytes, but never mB.  A small m means milli, 1/1000.
Ionut
Nope Mb= Mbits. Where MB= MByte which is 8x time. Bigger.
@Ionut wrote:
Hi there. There are still week signal spot and you experience 3G. For me work fine in that area.
I get around 50 Mb/s.
Correct your typo please.  I think you mean 50 mbits/s.  Mb implies Mbytes/s.  There is an 8x difference.
will13am
Depending on network congestion, a connection can be bounced around for load leveling purposes.  Sometimes you can end up being connected to a tower that may be far away or a 3G connection.
Ionut
