Someone used my code and...?
os54656
Hello!
Someone used my signup code last night and I was wondering if they have to be with public mobile for a while before I can see the $1 off or the $10 on their side. They also got the text saying their rewards and send a friend said $0.
Thanks!
 @os54656 : You should see the added dollar in your rewards area almost immediately. They'll see the $10 credit by 3 days but usually overnight.
Dunkman
@os54656
Typically, the new customer will get the credit in available balance within 72 hours.
You should be able to see $1 in your Refer-a-friend rewards area and you can even see the last 4 digits of their phone number. You use to get a text from Public mobile confirming that you referred a new friend, but that was been stopped for a while.
n8te
It will ususally appear after a couple days then it will last as long as the person is using the plan.
I saw that I had a 10 dollar credit the day after I activated with a friend's referral code.
