12-28-2020 12:59 PM - edited 01-05-2022 04:37 PM
12-28-2020 01:23 PM
Yes, you can do it. just make sure your sim card size (it's the same size as I know)
if you have a problem after putting a sim card on the iPhone, you should send a service ticket on how to unlock the iPhone.
네, 심카드 사이즈가 같으니 바로 빼서 끼시면 됩니다 ^^
아이폰의경우 유심 락이 걸릴 경우가 있으니 혹시 문제가 있으시면 서비스센터에 문의하세요.
12-28-2020 01:03 PM
In case of a size difference, hopefully you kept the frame pieces to snap back in to. Or carefully snap the smaller part from the larger frame.
12-28-2020 01:00 PM
@stephen2247 wrote:Can I take the SIM card from my galaxy 8 phone and use it in my iPhone 11?
@stephen2247 yes you sure can!😁
