09-20-2017 10:47 PM - edited 01-05-2022 03:17 AM
Hello, I've been having a lot of problems activating a new sim card tonight. Is something going on with the server? I've tried several times. Most of the time, after choosing plan options, I end up with the following message:
Generic Error
Oh no!
It looks like something went wrong, but don’t panic.
At other points, forms won't fully form (e.g. the form for selecting a phone number). Please help!
09-21-2017 09:55 AM
09-21-2017 09:03 AM
Thanks everyone. I've been trying since yesterday night with all of these suggestions with no effect.
@CS_Agent - tried again this morning but still encountering the same problems!
(Also, having issues posting to productioncommunity.publicmobile.ca - connection timeouts? Is this related?)
09-21-2017 09:02 AM
09-20-2017 11:19 PM
often switching to the french language can solve the generic error issue
09-20-2017 11:18 PM
Message the staff on the forums - I did it when I was having issues and they replied faster than the web help.
09-20-2017 11:08 PM
Another quick option to try is to clear the cache of whichever internet browser you want try.... It's a bit a shot in the dark, has fixed issues for others before. Best of luck and welcome to PM in advance.
09-20-2017 11:05 PM
i believe it may be a problem with your internet or with what search engine you are using. best bet is to use google chrome, the most trust worthy internet engine.
09-20-2017 11:05 PM
Thanks for the recommendations. Unfortunately I've tried both IE and Chrome - both producing the same errors. I'll go ahead and send the Mods a PM, thanks!
09-20-2017 10:54 PM - edited 09-20-2017 11:01 PM
I'm not sure what web browser you are using, but try Internet Explorer (PC) or Safari (Mac) as web browsers such as Chrome, Firefox, and others have caused issues for some when activating in the past. When I activated, I wasn't able to use Chrome and I kept on getting a similar error to you - Internet Explorer worked for me.
Otherwise you may need the help of the @CS_Agent. Just send them a Private Message with your phone number and account number (if you got that far), and I'm sure they can get you sorted. Cheers.
*** I'm glad to help but I'm not a moderator. Please don't send me your personal information. ***
