02-22-2018 01:46 PM - edited 01-04-2022 03:34 PM
Hi There...
I am becoming a Public Mobile customer and when setting up a Plan I noticed for Text the choices are 'International Text' or 'No Text'.
If I don't select either option do I get 'Local Text' or do I have to select International or No Text?
Thanks...
02-22-2018 02:00 PM
Thanks so much...I will select International...
02-22-2018 01:56 PM - edited 02-22-2018 01:58 PM
@Muskie99d You will have to select international text as there is no other choice to have local text.
