01-29-2021 01:08 AM - edited 01-05-2022 05:03 PM
How do I reset my security questions if I can’t log into self serve?
My Account
01-29-2021 02:33 AM
I haven’t seen a solution better than that one yet. Should I wait a little longer before picking one?
yeah I will wait till I’m back in and then pick one that is the best solution.
that answer is hard to top though.
01-29-2021 01:56 AM
@computergeek541 wrote:Please do not assign solutions to yourself. Solutions are often given as a thank you to other members who have helped answer your question.
Isn't that Bravos? Aren't Solutions the selected answer for the question?
01-29-2021 01:50 AM - edited 01-29-2021 01:54 AM
01-29-2021 01:44 AM
Oh that’s too bad. I wish people would not do shady stuff like that. Then we wouldn’t need passwords.
01-29-2021 01:37 AM
@Jasondimera wrote:Will public mobile be able to use my face as my login credentials? I don’t want to type a username or password. I want to click login 📱📸🤷🏻♂️📲 done! Or very least type my phone number then use the facial recognition on my phone or the camera on my phone. Not using my face to load a stored password. Use my face as the password.
make it happenI believe in you
you can do it!
I can't predict the future, but in my opinion, this is never likely to happen. In the past, there have been ways to trick facial recognition, as well as there not being 100% accuracy.
01-29-2021 01:33 AM
make it happen
I believe in you
you can do it!
01-29-2021 01:10 AM
@Jasondimera wrote:How do I reset my security questions?
Log in to your self-serve, Profile, Change Security Question.
01-29-2021 01:10 AM
If you can get into your self serve account, you can do that from there, but if you can't log in, you'll need to open a ticket by going to https://publicmobile.ca.ada.support/chat and typing "forgot security question answer".
