SIM failed to provision
KarinR
Port authorized SIM no good. Swapped  SIMs with another PM phone & didn't work in that either.
1 REPLY 1
slusagm
Ask PM to re-provision
 Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
https://productioncommunity.publicmobile.ca/t5/notes/privatenote
