SIM card
DBroder69
I have an LG 6 phone, which doesn't open in the back. How would I install a sim card?
DBroder69
Yep that worked. Thank you
It's on side of phone.
geopublic
@DBroder69  Usually there is a pin hole located on the side of the phone, you can use a paper clip to eject the sim tray.
How to: https://www.youtube.com/watch?v=L_JNDtX-8FY
