09-11-2020 07:54 PM - edited 01-05-2022 01:11 PM
I purchased used unlock device. B It works perfectly with bell sim card but when I insert public mobile sim card it requires SIM UNLOCK PIN.
How can I get sim unlock pin?
09-12-2020 03:46 PM
@gpixel wrote:@RosieR i think Samsung is the only one that asks for a sim unlock pin, when locked to a certain carrier. it's actually "sim network puk". other brands use "no service, invalid sim or sim not supported etc".
the description of the customers issue, is what led me to assume it was a samsung.
@gpixel I knew you had a valid explanation. I am learning something new here on PM everyday. thank you very much 😊
09-12-2020 02:25 AM
@gpixel wrote:@RosieR i think Samsung is the only one that asks for a sim unlock pin, when locked to a certain carrier. it's actually "sim network unlock pin". other brands use "no service, invalid sim or sim not supported etc".
It's not a Samsung thing. It's Android. Most brands call it that.
09-12-2020 02:24 AM - edited 09-12-2020 02:49 AM
09-11-2020 10:39 PM
@Anonymous wrote:
@RosieR wrote:
@gpixel wrote:@Vaibhavpatel you can also call Samsung to unlock your device
Hi @gpixel how did you know it was a Samsung phone? A newbie question. 😊
There's no evidence so I would say it was a guess and a way to try to help the customer.
@Anonymous ok thanks for the reply. I thought I missed something. lol
09-11-2020 10:27 PM
09-11-2020 10:12 PM
09-11-2020 08:49 PM
09-11-2020 08:26 PM
@Vaibhavpatel Sounds like the device was used not not unlocked. It needs to be unlocked by the provider that locked before you can use it with PM.
09-11-2020 07:55 PM - edited 09-11-2020 07:56 PM
Contact Bell to have it unlocked.
There is no charge for it.
