SIM NETWORK UNLOCK PIN required for SAMSUNG android
Salonduparadigm
Hello! I went on the SAMSUNG website to get a code for my samsung phone, this is what it says:
Power off the device.
Insert the alternative carrier SIM card into the device.
Power on the device.
Wait for device to display the "SIM Network unlock PIN" screen.
Enter your specific NCK code and then touch UNLOCK.
You must obtain your NCK code directly from your previous mobile provider. Samsung can not provide any NCK code.
Please help. Thank you.
@getterdonewelde wrote:
I got a code and installed the new sim but nothing asked me for the code.
This likely means already unlocked or its a Telus phone.
CS_Agent
Customer Support Agent
Hey getterdonewelde!
Thank you very much for being part of our community:)
Whenever the device does not ask for the network unlock code is most likely because the sim card is compatible with the same network of the device's original provider or is already unlocked.
If you have any further question or request, you can send us a private message, and we will be more than happy to assist you.
Kind regards
Public Mobile Moderator Team
getterdonewelde
Salonduparadigm
thank you, i am chatting privately with a moderator right now.
have a great day 🙂
CS_Agent
Hi Salonduparadigm,
Sorry to hear about the difficulties faced.
Let's continue on a private message!
