SIM CARD
Melvs
where is "call history" located in SEIF SERVE
HALIMACS
@Melvs
It's here on the self-serve landing page:
HALIMACS
@Melvs
You'll notice self serve usage not only shows call history but text history and daily data consumption.
You'd probably be better off using the devices call history if searching for a particular entry - unless you manage the account for someone else. 😉
@Melvs ,
See "View My Usage".
It is a cumbersome system. Wish it was nicer to navigate, but it gives you the dets.
 @Melvs : Click on View My Usage in the middle.
