11-27-2018 02:16 PM - edited 01-05-2022 02:36 AM
@Moderator_TeamI see for $20 you get 250MB data only. It's not very much. What happens when you have consumed your 250MB? How do you know?
11-28-2018 10:51 PM
That’s a great idea!
11-27-2018 05:21 PM
Once you have consumed your data it just stops working. PM will send text notifications letting you know when your getting close (75% used etc...) and how much you have left. PM does not charge more once you reach your data limit it stops until renewal or if you purchase more. 🙂
11-27-2018 02:39 PM
@funfunfun the $20 bundle gives you talk, text, and 250MB of data, and yes you can add more data after if needed.
The other option you could consider if you need all 3 services is to buy the $15 US Roaming Talk+Text bundle, and then separately buy 500MB or 1GB of US Roaming data. For short weekend trips, I have usually gone with the $20 bundle in the past, but for longer trips, bought the talk+text bundle plus data separately.
11-27-2018 02:36 PM
I see. The first $20 gives me talk roaming and a tiny bit of data, and after that I can pay more more more for data.
11-27-2018 02:34 PM
Once used up its done..then time to purchase more..you can track usage on your account profile and i believe warnings are sent when you get close..you can get more for 20$ tho
