09-12-2021 05:47 PM - edited 01-04-2022 05:26 AM
Hi.I refer a friend a month ago.When I will Recibe the reward?Thanks
09-12-2021 08:41 PM
It takes less than 24hrs. Contact customer service you'll need the person you referred to also contact customer service if they didn't get theirs either.
Cheers
Naepalm
09-12-2021 06:07 PM
you will see it in your account under rewards.
you will earn $1 every 30 days for each friend you refer to Public Mobile
if them still activated with public mobile.
if you go to your account and you can't see it at your rewards check it out with your friend the are sure enter your code when the activate,and you or your friend missing the rewards your friend have to contact CSA, to them can Add..
and your friend will receive a one-time credit of $10...they will applied within 72hr,,,
09-12-2021 05:59 PM
@Nenita1957 wrote:Hi.I refer a friend a month ago.When I will Recibe the reward?Thanks
Hello @Nenita1957
You should see the $1 and the last 4 digits of the phone number of your friend you referred under your Rewards referral list.
On your SELF SERVE account by clicking on the arrow pointing to the right, which will open up the list and the arrow will then point down.
If you do not see that friend's phone number than it was not used on activation or something went awry.
Did your friend receive their $10 credit in their Available Funds?
If so, maybe they typoed your referral code, but it was still a valid code...?
Check with your friend if they received the $10.
IF NOT, THEY are the ones that are going to have to submit a ticket to Customer Support and provide your referral code to them so that you can both get your reward/credit.
09-12-2021 05:59 PM
@Nenita1957 your $1 Friend reward should show up in your My Account on the same day your friend activated. Also, your friend should see his/her $10 within 72 hours.
Can you check if you friend ever see the $10 ? If none of you see the Friend Referral, usually is the referee to open a ticket with PM , so please have your friend to open the ticket .using Chatbot.
09-12-2021 05:51 PM - edited 09-12-2021 05:52 PM
Look in your account to see if it's showing there as a pending credit under Rewards.
09-12-2021 05:51 PM
Your $1 monthly reward will show in your account under rewards. It will be applied to your balance on your next renewal.
