01-16-2020 06:28 PM - edited 01-05-2022 09:03 AM
Hi I was wondering if I could get some help. My password didnt seem to save on firefox and it was a generated one. Now I do not know the password. I went to reset the password and it said it sent to my email. I got no email yet its been quite awhile. How can I get into my account? I need the password reset
Thanks
01-16-2020 08:19 PM
A password reset almost always will require moderator assistance. Click ?, bottom right, and follow instructions to submit a ticket. Moderator wait time can be a few hours or sooner, or within a day.
01-16-2020 07:51 PM
@zlares wrote:Reset password done but no more data.
If you used all your 30 days' data, here are your choices
1. If your current data limit does not meet your 30 days' need, you may change a plan with more data. You can do the plan from self-serve. You get your data back immediately with plan change.
2. If you want to renew the same plan early, you need to create a moderator support ticket using the ? button at the bottom right hand corner of this page. Moderator wait time is within 1 day. If your next renewal date is 1 day away, you may just on data diet for a day until after renewal.
3. You can buy data add-ons $30 1GB data or $10 200MB data. Expensive option
01-16-2020 07:26 PM
01-16-2020 07:09 PM - edited 01-16-2020 07:10 PM
@Kvothe Check you junk/spam folder just in case it's there. If it's not maybe there was a typo when you setup your email during activation. If that's the case you need to submit a ticket.
01-16-2020 06:46 PM
Try again, sometimes website gets slow than picks up
Im assuming you checked junk folder too
Do you have any filters set that would place the email in a different folder than inbox?
01-16-2020 06:34 PM - edited 01-16-2020 06:35 PM
@popping wrote:
@Kvothe wrote:Hi I was wondering if I could get some help. My password didnt seem to save on firefox and it was a generated one. Now I do not know the password. I went to reset the password and it said it sent to my email. I got no email yet its been quite awhile. How can I get into my account? I need the password reset
Thanks
Email may take couple hours.
You can create a moderator support ticket for help using the ? button at the right side bottom corner of this page.
I just try the password reset and I receive my reset email less than 1 minute.
@Kvothe , Please try again.
01-16-2020 06:31 PM
Thanks
