Remove Voicemail
afoote30
Hi,
I need to "remove" voice mail entiredly from my current plan as i have this forwarded to my work phone and the voice mail stops the call from being forwarded.
How is this done?
8 REPLIES 8
@popping  thanks for heads up. I'll admit this one I read up to "I need to remove voicemail entirely" .... Did not bother reading the rest. That one bit me in the buttocks 😂😝
I X'd my reply out. Thanks!
popping
@gblackma wrote:
I would attempt @Jb456  suggestion first @afoote30 . Since, in order for you to continuously forward your voicemail to another phone, you would have to either have a dual sim phone, or another phone with SIM in, that you have to keep charged.
I am not sure whether the phone need to be charged 24/7.
I think PM will forward your call when your number is not reachable.  I am aware of the thread for call forwarding while in US.  My interpretation is that the number is unreachable if the phone is turned off.
gblackma
Did you unconditionally forward your calls @afoote30 ? I can't understand why voicemail is picking up if the number is unconditionally forwarded? Thanks.
popping
@Jb456
OP wants to forward calls to work phone.  Setting extended absence is not what OP wants.
@afoote30
Follows @LovesToPM suggestion to set up call forward to your work phone.
@afoote30 wrote:
Hi,
How is this done?
There's no removing voicemail. Set your call forwarding options as LovesToPM linked.
LovesToPM
@afoote30
You can also check here to see your call forwarding options:
https://www.publicmobile.ca/en/bc/get-help/articles/call-forwarding
Jb456
See this link.
           CLICK HERE
