Remove 'Public Mobile' from notifications bar
07-12-2019 05:13 PM - edited 01-05-2022 05:51 AM
That's some prime real estate there. I had 'Koodo' showing up on it for the longest time and that was bad enough. Public Mobile is a long name. PM would be better. No carrier name at all would be ideal, though!
I know there may be a possibility if I root my phone. Is there anything less drastic?
Joining Public
07-12-2019 05:51 PM
@mykllkym I have similar problem as Public Mobile is missing on the top left corner.
07-12-2019 05:32 PM
I have Android 6.0.
I can only remove it to my knowledge. Settings --> More --> Cellular Networks -->
Then take the checkmark out of Show Mobile Sim Network.
07-12-2019 05:31 PM
I assume you're using an Android phone. Rooting is definitely an option.
For me, "Public Mobile" is displayed only on the lock screen.
There are third party lock screens you can opt to use.
You can also try this: https://www.lifewire.com/customize-your-android-lock-screen-121655
07-12-2019 05:25 PM
If your using a custom android Rom you can rename it your self, however i know the average user has no idea what those are, i always recommend giving custom ones on android a spin as the options alone are worth it.
07-12-2019 05:16 PM
what phone do you have some have the ability to hide or rename the carrier name.
