Registration failed
Ronnyng
I need to sign up to Lyft (apps) but it say :
we are unable to contact the number you provided. Please make sure it's correct and try again.
its urgent cause I need Lyft.
2 REPLIES 2
Daps
You can try this
  1. If you're still logged in, log out of the app in the 'Settings' tab, then close the app on your device
  2. Text START to 46080 and follow the instructions
  3. Restart your device and re-open the app
  4. Tap 'Get Started' and log in
  5. Use the code we text you to verify your phone number. Don't tap 'Resend code.' Messages received out of order prevent logging in.
  6. If you don't get a text after several minutes, tap 'Problems receiving the code?' We'll call your phone with a verification code.
If you don't receive a verification code after following the steps above, contact your provider directly and ask them to enable the following short codes: 46080 & 55074. Once these short codes are enabled, try logging in again.
Jb456
Stay Safe!
