03-22-2021 01:19 AM - edited 01-06-2022 01:31 AM
03-22-2021 06:15 AM
@Casadeoro wrote:Where could I get code for referrals
Any one with an active Public Mobile account has their own unique referral code, so asking in this forum for one you should have no problem obtaining one (or many).... @TheGx has you covered.
Once you have your own phone number/account, then you can use your own unique code to refer others! The code it located in you Self Serve account, top, right of the opening page. It is a 6 digit series of number/letters.
03-22-2021 01:32 AM
@Casadeoro :Click on the envelope button in top right corner for the referral code sent you.
03-22-2021 01:31 AM - edited 03-22-2021 01:37 AM
@Casadeoro : So johnny on the spot has you covered for you (and probably a bunch of others) ...but just in case you're meaning for you to give to others...your referral code is in your self-serve on the upper/middle right side. It's 6 alpha-numeric characters.
03-22-2021 01:23 AM - edited 03-22-2021 01:27 AM
@Casadeoro :Use mine, I'll send you mine by private message right now.
