Refer-a-friend
07-07-2019 10:53 AM - edited 01-05-2022 05:46 AM
Hello guys,
I just refer-a-friend to Public Mobile and she set up at Walmart yesterday, but the staff did not enter my number when she helps to active the sim card. If anyhow I can fit it.
Joining Public
07-07-2019 01:45 PM
07-07-2019 01:19 PM
Sorry to hear your situation, it is better for you to connect with the moderator team and also tell your friend to connect with the moderator team about the situation. Generally, they are quick and reasonable. Unfortunately, I am also not a big fan of Walmart when it comes to mobile phone activations. Good luck!
07-07-2019 12:42 PM
I had a co-worker experience a similar, if not identical problem. Once activated; cannot be undone.
The only way to start a new account with a new number.
07-07-2019 11:58 AM
I think wherever the activation was done, they have a hotline that they can call for problems about activations and I think this is that kind of a problem.
I have read that you might be out of luck once your friend activates his or her number but then didn't do your referral but you can have your friend try to check with Walmart where they did the activations or as other people said here, try the moderator. Just PM then to check if they can do something about it
07-07-2019 11:03 AM
@Kind333 it is best that your friend contact the mods as they will need to verify her account with her. they typically ask for a sms verification code or the person to log into their account.
Either way make sure she creates a selfserve profile
07-07-2019 10:56 AM
@Kind333 Hi you will have to contact a moderator here https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
07-07-2019 10:50 AM
Hello guys,
