Realme X compatibility
jj2001
Does Realme X India work with public mobile?
@ChuckYeah wrote:
http://willmyphonework.net reports limited compatibility. If I were you I would consider taking it to a Public Mobile vendor and see if they can test a sim in it for you. Or use a friend's if you know other people on PM. The one @will13am has listed appears to have many more bands so it would be great if you have one like that.
Sub model is key.  Personally I would shy away from using Asian phones on Canada.  Generally they use different bands for 3G and TD-LTE and FD-LTE are totally different beasts.  This is what I can find about cellular bands in India.
https://www.frequencycheck.com/countries/india
will13am
@jj2001 , is this the sub model?  If so, it is compatible.
https://www.gsmarena.com/realme_x-9700.php
