Reactive my account please
rrwfreedom
I have topped and changed the plan since service been suspended at renewal day which can is today, but still not back to active, please help
Shazia_K
Retraité / Retired
Retraité / Retired
Hey @rrwfreedom,
I'm sorry about this,
I was unable to locate your account, is it possible to send me a private message with your Public Mobile phone number?
Thanks,
Shazia
Try rebooting your phone and also check your account to ensure it now says active and the plan is correct.
While you are doing that let's notify our moderator @Shazia_K to assist you in case that does not work.
rrwfreedom
Still not working
NDesai
If you have sufficient funds and your account currently says Expired, don't worry, everything will be normal by tomorrow morning. You should not have any interruptions with the services.
