Reactivated SIM
06-29-2020 01:13 PM - edited 01-05-2022 11:53 AM
I'm hoping to use my old PM SIM to reactivate my account - but its not workings - thoughts?
Phones
06-29-2020 01:26 PM
@kschnare Another option is to buy your SIM card from Canadian cell supplies https://canadiancellsupplies.com/collections/latest-products/products/public-sim-card
Currently its $3.33 each.
06-29-2020 01:23 PM
I did port out my number = its true- thanks!
06-29-2020 01:19 PM
@kschnare wrote:I'm hoping to use my old PM SIM to reactivate my account - but its not workings - thoughts?
Activated SIM card cannot be used again.
If your PM account was canceled, it cannot be activated again. You need a new PM SIM card.
06-29-2020 01:15 PM
If you had ported out your number or had let it remain in suspension for more than 90 days then you can't re-use the SIM.
Otherwise all you need to do is top up to pay for the plan (or change the plan if you like) and it should reactivate.
