02-01-2020 03:32 PM - edited 01-05-2022 09:17 AM
I have lost my phone including my SIM card. Can I activate a new card under my account online?
02-16-2020 05:08 PM
@SSB2 Glad you got it all sorted out, and we appreciate you returning to the thread, and updating it, so that others that may run into a similar issue might find the info useful. 👍
02-16-2020 05:04 PM
Thank you for all the help. I have been able to get another phone and new sim card and I am up and running!
02-01-2020 05:27 PM
yes, I think so.
02-01-2020 05:18 PM
A sim card can be changed after logging in to self serve overview page. If an issue arises with changing sim, refresh page and try entering info a little later. Hope another phone can be found soon.
02-01-2020 03:54 PM
Sorry to hear that @SSB2. You should also consider Changing the passwords of any email address, cancelling qnd changing any credit/ bank cards etc that you may have had associated, loaded onto your cellphone.
@SSB2 wrote:I have lost my phone including my SIM card. Can I activate a new card under my account online?
02-01-2020 03:35 PM
1. Get a new PM SIM card
2. Login to your self-serve account
3. Click on "Change Sim Card" link on the overview page after login.
02-01-2020 03:35 PM
@SSB2 , you can change SIM cards in your account. Just login to the self serve and change SIM card. Enter new SIM card number and that's it. In the mean time, I suggest declaring your phone lost in the account so that the use of the old SIM card is suspended.
02-01-2020 03:34 PM
You sure can. Log into your self serve account and click change sim.
Green arrow on pic
02-01-2020 03:34 PM
Yes. Unlocked, compatible phone. New SIM. Change SIM in self-serve.
