Re: iPhone 7
Options
12-09-2023 04:13 PM
I just purchased a public mobile account/package and SIM card. Currently with bell. Bell says my phone (iphone7) is unlocked but still can’t get public card to work. Can someone help ??
2 REPLIES 2
Options
12-09-2023 05:07 PM
Are you porting your old number over to PM or are you picking a new number?
Options
12-09-2023 04:16 PM
try to click Reset Network Settings first
And do you have another phone to test the sim card? If still does not work, it could be a problem with sim card provision Easy fix for PM support but please engage them by messaging:
**Monitor your Community inbox (envelope icon on top right) after the ticket is opened. CS Agent will reply to you there
