Re: Switched from Rogers - can't receive call or receive/send text Need Escalation
Ryanblain
Can you also send me the #? Having the same issue too thx
1 REPLY 1
slusagm
@Ryanblain
there is a porting assistance team you can call and ask for update.  I can't post the number here, but I will message the number to your community inbox.  Please check and call them
But if you cannot reach them or they said they cannot help, you will need to contact PM using this link
 And CS_Agent will reply to your community inbox, check here:
https://productioncommunity.publicmobile.ca/t5/notes/privatenote
