05-01-2025 06:09 PM
I have the same issue. Changed my plan on renewal, and now I have no service. Restarted my phone, ejected SIM, reset network settings, and nothing has worked. Hopefully they are helpful and can resolve these issues.
05-01-2025 06:13 PM
hi @chadwiccck
since you already tried the usual things and still unable to get data back, just more thing to check, make sure there is no data limit set
And ask PM support agent to help. Submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit ticket by direct message:
05-01-2025 06:11 PM
common problem now. If restarted phone didn't help, you will need PM to help
Just open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.) Type the question Submit ticket and select Contact Us to get to ticket open screen
Or message them using this link:
