10-03-2025 02:04 PM
I have the same problem than you! No 5G or even LTE since 3 days days
10-03-2025 02:38 PM
The ticketing system is broken right now.
Is talk and text working?
You might want to try network reset of phone (note: this will erase any saved Wifi passwords).
Manually select LTE network. Or 5G network (if in your area)
10-03-2025 02:10 PM
Yes of course 3 times since two days already and I don't have any answer from them...
10-03-2025 02:08 PM
i have the same problem since 3 day i start to become crazy
10-03-2025 02:07 PM
have you open a ticket with PM yet?
Simply open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA code when login, use email to receive code instead of SMS if you cannot receive the text on the phone.) When open Chatbot ticket, Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble using Chatbot to open ticket, then message PM using this link:
PM will reply to your community inbox, between 9AM-10PM EST (Mon-Sun), check here:
