Re: How Do I contact Customer Support!??
Nuuisha123
My number isn’t working
Jenks44
Bloody terrible service.  I keep getting put in a loop - won't accept a new password, reset, won't accept.  I guess this a way to keep you on their service indefinitely.  BRUTAL !!!!
JL9
Is this a new activation? Did you port over a number?
@Nuuisha123
To contact the Public Mobile Customer Support Agent (CSA)_Team, there are two methods to reach them:
1 -  Faster  use this link to: Get Help With SIMon the Public Mobile chatbot
OR
2 – Slower - Use this link to:
Contact Public Mobile Representatives (CSA) by submitting a message(ticket) to them here:
Private Message to Public Mobile Customer Support Agents (CSA)
But maybe we can help.
Are you a new or existing customer?
If new did you activate with a new number or a ported over number?
Try one or more of the below for network / service issues:
*turn off your phone, then reboot
*removing your SIM, then reinserting it
*go into airplane mode, then going back to regular mode
*perform a reset network settings on your device
*try your SIM card into another compatible phone for a few days to see if the issues are the same...this could rule out a device issue/setting.
*manually select the 3G / WCDMA ONLY network in your Mobile Connections area in your settings (temporarily) for dropping or unable to make incoming/outgoing calls
*Is your phone locked? Contact your previous provider to unlock it for you. You will need your imei number, dial *#06# to get it.
*Check if your phone is blacklisted here: https://www.devicecheck.ca/check-status-device-canada/
darlicious
@Nuuisha123
Call 611 from your phone to get your basic account details. When was your renewal? Last night? Which plan do you have? $10? Signed up for autopay?
To pre-verify your account include in your private messaging only your full name, address, email, phone # and 4 digit acct pin #.
