Re: Forgot password.
sunilc
I forgot my email id and password. How can I login to my account to change my plan.
Sunil
1 REPLY 1
Sunil
You'll need to submit a ticket to get both of those reset.  Normally, you would use the password reset feature, but that requires you to know the e-mial address that was used.  Go to https://publicmobile.ca.ada.support/chat/ and type in "rep".
