Re: Chat bot incorrect, Public won't correct the issue, Managers non existent
RyanE
Hey bud: I need to set a 4 digit pin, everytime I call in to add funds with a credit card it asks me a 4 digit pin and I did t set one up! If I could set it up plz let me know l I'm supposed to have auto top up but for some reason it never works, to no fault of public mobile however!  So I'd sure like to set up a 4 digit pin thank you
@BKNS27 wrote:
@computergeek541
If the OP calls 1-855-4PUBLIC. Would it ask for a PIN?
Yes, the account PIN is required to make a credit card payment.
@computergeek541
@BKNS27 wrote:
@RyanE
You can reset your PIN if you haven’t create one or forgot your PIN. Login to your account then on the Account tab>Reset PIN Number.
Some customers, specifically newer ones would have never been asked by the activation systerms to create an account PIN. For those customers, the app cannot be used to reset an account PIN that doesn't exist.
@RyanE
you can setup your 4 digit pin by using this link
https://myaccount.publicmobile.ca/en/account/reset/pin
@RyanE
