Re: Can't Receive/Send Calls or Texts
Kileyrae
I am having the same issue. Some texts are going through and some aren’t, hopefully this gets fixed. I’m new to public mobile and so far it hasn’t been a good experience, issue after issue 🙄
1 REPLY 1
slusagm
@Kileyrae
did you remove your old sim card or disable the old eSIM? make sure Public Mobile is the only one there
and are you not receiving 2FA? remember 2FA from US or other countries might not work
and if you just ported your number into PM for only couple days, some Canadian 2FA would take 3 to 7 days to start coming
