07-22-2026 11:20 AM
Am also being charged the additional $5, even though I have changed to a 4G phone as per the PM texts received. NOWHERE in their texts did PUBLIC MOBILE indicate that we now also need VoLTE compatibility. What else is PM not disclosing in order to charge more???
07-22-2026 06:15 PM - last edited 3 weeks ago
@Girardi the need of VoLTE is now for all providers, not just Public Mobile. The way of using 3G is going away
What phone are you using? and which province you are in?
You are charged the $5 extra for using an old device was because PM would like everyone to change to a device that is compatible with PM network before end of March 2027, when 3G service will end. After March, all non-compatible devices will not receive voice calls
Your phone might be a 4G or 5G device, and your phone might has VoLTE itself, but it has to be on PM's VoLTE whitelist.
Since you got the $5 charge, your phone likely not on the list. better to check it yourself and confirm:
https://www.publicmobile.ca/en/get-help/articles/volte
if it shows your phone is not VoLTE approved on PM network, you should get another phone that is on the list to avoid more voice call issues
But if it shows your phone is VoLTE approved on PM network, then it was charged wrong, you can ask PM to check and remove the charge.
Simply open ticket with PM using Expert Messaging. Click the Orange Chatbot icon on the lower right to start, or use this link https://expert-messaging.publicmobile.ca/guest/chat/
(Use your Community account to login. For 2FA, you might need to use email to receive if you cannot receive the text on the phone.)
PM will reply you via Expert Messaging between 9AM-10PM EST (Mon-Sun)
(for help with Expert Messaging, check here: https://publicmobile.ca/en/get-help/articles/expert-messaging )
