2 hours ago
- last edited
2 hours ago
Hi, can I please have the number as well?? Mine is still not activated for almost 3 days I’m getting frustrated and migth have to cancel the whole thing 😭😭😭😭😭
thanks
2 hours ago
Yes, There is a number to call to talk to live support, they can provide you the update and/or re-trigger the process for you. I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) . Check the envelope icon on top right. Call them and get it fixed
But if you are unable to reach a live support with the phone number I sent you, please message the the support team using this link instead:
**Monitor your Community inbox (envelope icon on top right) after the ticket is opened. CS Agent will reply to you there
