09-25-2020 03:46 AM - edited 01-05-2022 01:20 PM
Hi i bought a new sim some days ago, activated, choose a plan, sim keeps saying "unregistered sim" and when i try to make a call it says not registered on the network.
09-25-2020 03:53 PM
@Okar hi, contact customer support mods
click on the question mark chat bubble to the bottom right of your screen
type "no service"
(use the chat bubble options, then click "submit a ticket, click me" option)
*login using your community account
make sure to check your inbox(top right corner envelope icon) periodically, for a response
09-25-2020 11:51 AM
I would make sure the phone is compatible with this network first and that the phone’s unlocked. You can contact your old carrier to have them unlock it for you. The link below will allow you to see if the phone works on this network.
https://www.publicmobile.ca/en/on/get-started
I would first try powering down your device and removing the sim card and, if possible, the battery. Wait a minute and then reinstall the sim and battery. Restart your device.
If it’s still not working, navigate to your settings and mobile network settings. Be sure that network selection is set to automatic.
If the unregistered SIM message continues, the SIM card may be faulty, and you’ll have to get another one either online or in-store.
09-25-2020 06:02 AM
Hello @Okar ,
Try one or more of the below:
*rebooting your phone
*removing your SIM for a few minutes, then reinserting it
*go into airplane mode for a few minutes, then going back to regular mode
*reboot your phone again
Is your phone perhaps locked by the previous provider? You can call them to unlock it, at no charge.
09-25-2020 04:21 AM - edited 09-25-2020 04:22 AM
@Okar Unregistered sim means not activated properly. Click on the chat question mark symbol to open a ticket.
