Qukitel wp6
hanymcanada
I purchased (Qukitel wp6) a few days ago, the network is perfect but the data not working, the problem is to contact the to a moderator to amend my problem I should use the IMEI of the phone which is not identified by the Community system I tried hundreds time but I failed. Please any idea?
2 REPLIES 2
gblackma
@hanymcanada try editing you APN settings. Use # 3 below
Welcome to PM.  Stay safe.
geopublic
@hanymcanada  You need to make sure you are using the correct APN settings.
Make sure data is turned on and you have the correct APN settings.
