Questions re phobes
aaronpbsmith
Does anyone know whether a refurbished iPhone (from Public) will work on other networks? My dad is on Fido (Rogers) and needs a new phone.
@Bookdart wrote:
any phone sold after December 2017 in Canada has to be unlocked by the regulation unless you are getting a really really old one. I'd say you are fine
Even then, for such a locked phone, the carrier must get it unlocked if it's locked to a Canadian carrier.
Bookdart
will13am
@aaronpbsmith , the major brands all use pretty much the same frequencies with a few exceptions that don't really affect performance.  The Public Mobile phone will work with Rogers and sub brands.
all device is it unlocked
you use it anywhere you like
