Question for porting from Fongo
canavan
Activation with new PM number is done.
I tried to port number from Fongo however I saw WIRELINE NUMBER TRANSFER page.
Just wondering if it is okay I fill out everything to port Fongo number or I have to fill out thru wireless transfer page.
Does anyone have experience about it?
i01190
I have ported Fongo number to Rogers, it was consider as a landline. Now i am waiting for it to be ported to PM again.
SD08
Fongo is considered a VoIP service, and therefore a wireline, for the purposes of porting.
I believe the timeline for porting from a voip service or landline to a wireless provider is usually significantly longer than wireless to wireless (about 2 bus. days?).
Rockdaddy22
Yes it is
If it's asking you to do it, then you should give it a try.
ERICJIANG
Is Fongo number even transferable?
