12-13-2021 12:26 PM - edited 01-04-2022 04:58 AM
I carrier locked my phone and cant use it because I don’t know the Puk!
Phones
12-13-2021 01:18 PM
@Rod1979 wrote:I carrier locked my phone and cant use it because I don’t know the Puk!
Contact Customer support to get the code:
12-13-2021 12:31 PM
Here is an explanation by one if the Oracles, Luddite.
SIM network PIN blocked. Enter SIM network PUK." is asking for the phone’s (often Samsung) “master code" after entering the wrong code too many times. Samsung and/or your previous carrier can give you this.
"SIM network unlock PIN" is asking for your previous carrier's unlock code - just contact them with your IMEI and they'll give it to you. If you enter this incorrectly too many times, you'll get the error message above.
“PIN unlock key (PUK)” is a SIM-specific code used to prevent unauthorised use of a SIM card.
The PIN (Personal Identification Number) enables secure access to the SIM card and network. It is provided with your SIM card.
If the PIN code is entered incorrectly 3 times, the phone is locked (except for emergency calls) and requires a PUK (Personal Unlock Key) to reactivate it.
Once the PUK is recovered and validated, you will be asked to choose a new PIN.
Only Public Mobile's CSAcan give you this type of code, which the device manufacturer cannot. CSA can be contacted at the following address: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Caution! If the PUK is entered incorrectly ten times in a row, the SIM card becomes unusable.
12-13-2021 12:29 PM
@Rod1979 Contact customer service agents.
Open a ticket via:
https://widget.telus.tiia.ai/publicmobile/publicmobile.html (faster response time)
Type "ticket" > Click "Contact Us" > Select your issue > "Click here to submit a ticket↗"
or send a private message to:
and describe your issue. Include your name,phone #, account #, Email address,4-digit PIN to speed up authentication process.
12-13-2021 12:28 PM
Where To Find Your PUK
A Personal Unlocking Key, or PUK code, allows you to reset your SIM card’s PIN number, after you’ve entered an incorrect PIN three times. To get your PUK code, please start a conversation with our virtual assistant, SIMon, to submit a ticket to the Customer Support Agents by clicking here link,.
