Puk code
Sexybutt
I need my puk code
2 REPLIES 2
@Sexybutt wrote:
I need my puk code
The default security PIN1 on your sim card is 1234.  It remains at that code unless somehow has manually changed it.
The sim card's PUK is only asked for if the PIN1 is repeatedly entered incorrectly.
The only way to get the sim card's PUK is to ask Public Mobile for it.   https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
popping
@Sexybutt wrote:
I need my puk code
Send a private message to moderator for the PUK code.
